Skoda superb 2.0 tdi turbo limp
Hi car keep going into limp mode
Does any one know how to clean the turbo
If you can get the car codes read with vcds this will help ID problem more quickly. I see that you have posted on superb section too - I have VCDS and not too far away. PM me and I'll try to assist.
Also check the rubber vacuum tubing to the wastegate has not split or perished - this will stop the turbo variable vanes working properly and will cause limp mode. Also N75 valve diaphragm may have perished.
I would try these 2 most likely causes first before trying to clean turbo.
Read thread for info.
http://www.briskoda.net/forums/topic/181241-vnt-turbo-problems/#
Hi the code is 16618 if it's help
