poor starting
2005 tdi intermittent poor starting sometimes all the dash lights are not on been told its the clocks can I just put new ones in with the same part nomber
In answer to your question about the clocks no you cant just change them the key code would need to be programmed in. A scan with vcds may highlight the statting problem, Regards Tony
