Autobrite Snow foam lance
Hi. My Autobrite Snow foam lance arrived today. Somewhat disappointed that there were no instructions.
Anyone tell me what the two 'controls' do? There's an adjuster on the top that I guess is for air/fluid ratio and then the nozzle adjusts what appear to be tweezers in the end :)
Is it 1" of soap then top up with warm water in the bottle too? Thanks.
1" of concentrated snow foam and top the bottle up with warm water. But do play around with those ratios slightly.
The top dial controls the mix between water in the pressure washer and the snow foam mixture in the bottle. Again, play around with it to see what gives you a sufficiently thick enough mixture to cling for long enough.
The fan controls the spread of the mixture coming out. Again, play with it to see what effect it has (you can try this one with just water in the bottle).
To start with set the top dial as far as it will go toward minus - this gives least water (strongest dilution foam)
Set the mouth opening to somewhere between 0.5mm and a hairs width and give this a go.
If you have your in bottle dilution correct this should fly just fine.
Then tinker to suit either for chemical economy,cling or just for fun.
+1 ^^^^^ what he said!  :thumbup:
Thanks guys. Hoping for decent weather now so I can snow foam the cars :)
Good choice-better than the others available. Did you get some magifoam with it? Valetpro ph neutral snowfoam is very popular when you need to get some more, but make sure its stored somewhere out of the cold or the contents seperate out ( but this is fixed by warming it up again) have fun......
I've also ordered some valet pro ph too. Not arrived yet tho.
Had a great time with the snow foam today.
Very nice - your car looks fantastic :)
Scottish car?
Scottish car?
Registered in Ayre I think. Lives in Shropshire tho.
Ahh my old Fab was registered up there and lives in Wales
Very nice!
Love that colour
