vRS camber settings
Does anybody have the definitive revised front and rear camber values for the 1Z vRS?
Can't seem to find anything concrete on here so need some advice. Cheers.
Presumably you are concerned that your settings are incorrect?
If you go to a proper specialist, one using something like a Hunter jig, then they will have the latest specs on their computer.
The machines are "on line" and updated when necessary.
Been to a couple of places with Hunter jigs.
In all experience, the operators have no clue how to utilise it.
Trying somewhere else now on a different machine. My rear camber has never been set to 1deg 20" - so I guess that is the revised setting for the vRS?
I did say a proper specialist... There are a few about.
The skill of the operator is always more important than the name on the side of the equipment.
Is your car checked with its normal load? You could be a photocopy salesman for example.
Where have you tried?
Tyre fitters are generally not well trained.
