Mk1 Octavia Service Advice
Hey guys
Picked 2002 Skoda Octavia 1.9 tdi AVS enige with 114k on clock. Car has part service history but very tidy for age and mileage.
Planning to do service next week so ordered all filters and oil.
Here is questions:
Timing belt intervals on AVS engine? I have record showing it was changed in 2008 at 58k.
Also was reading about oil pick up pipes, does it needs changing too?
What else would you advice to change?
Many thanks
Timing belts are 4 yrs or every 60k but I work for audi and they say 5yrs 75k for same engines? But think I'd stick to 4yrs 60-70k really? And while your there throw a water pump at it for piece of mind as the plastic impellers fail over time!
As for oil pick up never only change them on 1.8t engines? If I was you I'd do all the filters so you can start a fresh and then your no the next service is just a oil change!
Hope this helps
Thanks much appreciated.
The worst thing not sure when it was replaced last. In service book says last time in 2008 at 58k have no records after this.
Ordered all filters and oil.
What is oil capacity in AVS engine?
I assume you mean an ASV, its about 4.3 litres.
Thanks yes it's ASV
