Monte Carlo 2011,, Horn Location Pls
Where is the Horn Located as difficult to Find on ones own.
Thanks  (want to replace it with a proper one).
There are threads in this section  on fitting other Horns.
Is it maybe here on Monte Carlos.?
So front beneath battery,, hope I don't have to take car apart? lol
A video on YouTube shows you where it's located and how to change it. It's located in the grill next to your fog light / drls on the passenger side (I can't remember if the video shows if it's a LHD or right so it could be the opposite side.
Double post.
pull out fog /drl lens nearside  you can see horn straight away changed mine on my monte
will try tomoz,, thanks
What sort did you go for Phil?
Just went to my local motor factors same sort of size not really loud but brtter than the standard moped one
Mine was for my VFR but first time I bottomed my forks and dented mudguard, removed it.. so fitting to monte.. lol
That sounds expensive!
The standard one is pretty feeble!
