2 fog lights or 1?
Only one of my rear foglights works on my fabia. I have looked and there are 2 bulbs but only one works. I have swaped out the non working bulb for a known good 1 but still no joy.
spoken to a dealer adn they said it only had one on the rear but why have skoda put a bulb in both but only wired 1 to work?
so i ask is the deaker lying or should only one foglight work on the rear?
Thanks for your help
Carl
Carl
IIRC most cars only have 1 fog light....my Octavia only had one but is now wired up to have both working.
I assume you'll probably have to do the same if you want both to work.
1 fog light only :)
edit: the reason for 1 rear fog light is 2 can be confused for break lights
cheers guys, my mind can now rest easy :thumbup:
Its a spare bulb !!
they put 2 bulbs in as it's easier to make all bulb holders the same and just stick them in, rather than muck about so that half have only a single filament and is put in one side or the other depending on a LHD or RHD model
