DRL's Dead, Monte 2011
Switch next to fuses in correct position.
Have exercised it.
Removed plug from rear of switch and refitted.
Shorted out plug connection. still no joy.
Can't see a fuse for DRL's, is there one.
Help pls.
There should be a fuse for the DRL's, I'm 99.9% sure ive seen it in the book. If no one has said which one I'll take a look in the morning.
thanks am away from home so no test gear,
wondering if ECU has disabled it as l attempted to feed Sub 'power on signal' from this switch as suggested.
but DRL's go off when lights switched on.
