My VRS has an odd engine noise
This is frustrating me now lol, i seem many posts about similar but no-one has ever got to the bottom of the issue.
I will have another try at explaining it and what I tried so far.
So when the engine gets up to temperature I notice a squeel / schreech noise this noise often gets a little louder and immediately back to a dull squeel. I doubt it's a belt and i'l explain why further down. I listed with the old screwdriver trick and the noise seemed more noticeable when place on the alternator. I spent £166 on a new on to find it wasn't that lol.
It was then that i realise something else. When i pull up on the drive and its making the constant squeel / schreech I shut the engine off and then as soon as its off the noise continues for about 3 seconds. I say continues once the engine is off its sounds more like i loud chirp than a squeel and that to me rules out any belts or bearing as when i shut the engine off everything stops. The chirping gets quieter and quieter and is then replaced by a loud hiss which again gets quieter until gone
Maybe an experienced mechanic might  have known?
Anyway, has stored energy and  is releasing it when the engine is not rotating . So a vacuum circuit leaking (brake servo?) to produce a musical note or a bizarre fault involving multiple electrical failures and the alternator being motored by the battery?
Goodness knows. Good luck with the diy.
Ok so i went to a garage who offered to listen to it for me
He said it sounds like an electric motor of some description but want £60 plus vat to look further.
what electric motors are there in the engine bay?
Sounds like you can hear the throttle valve resetting, my TDI does it too when you turn the engine off.
Trev
I don't know if its the same engine or not but I did some work on a friends seat leon cupra r and there was a little electric water pump situated just behind the radiator that used to run on for a short while after the engine was turned off to continue to circulate coolant. may be wrong but just a thought.
