Octavia Mk3 Strange VCDS behaviour....
I have a genuine VCDS cable running 14.10 software. The cable is a Micro CAN, which works perfectly on my Mk7 Golf. However, on the O3 it doesn't work particularly well in Autoscan mode. When I do an Autoscan it seems to be able to scan some modules without fault and then it says "Cannot be reached" for certain modules (42 drivers door and 08 HVAC are the current favourites).
I can reach the module if I select it and recode it. If I repeat the Autoscan, it is not always the same modules which "cannot be reached". Any ideas on what is going on?
When I start the Autoscan, it seems to be able to see all the installed modules and reports back with no fault found and then cannot see the module. Here is an example of what is happening.... I've deleted bits of the scan but you can see that the status of all the installed modules is OK but then some modules can't be reached with the scan!
Tuesday,06,January,2015,18:06:26:26904
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: TMBBG7NE3Dxxxxxxx License Plate:
Mileage: 19594km-12175mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 5F
VIN: TMBBG7NE3D0033243   Mileage: 19594km-12175miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012032501090000
   Shop #: WSC 73430 031 00125
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021AL.rod
   VCID: 2F43DF1476745459C61-807A
No fault code found.
Readiness: 0 0 0 0 0
Address 16: Steering wheel
Cannot be reached
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000512622
   Coding: 030100040B087300EF000648080F00010001000000000000000000000000
   Shop #: WSC 73430 790 00125
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear.rod
   VCID: 3449D0789F527781BB3-8061
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0100
   Serial number: 000000000B0356160413
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8446110403
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B76765D525220343E00
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B7BCB04426C2879EA9-807E
Address 42: Door Elect, Driver
Cannot be reached
Here's a complete scan for reference. On this occasion it is 17 and 42 that can't be reached.     :wall:
Tuesday,06,January,2015,18:48:54:26904
   Revision: 84H22---
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Revision: 00000000    Serial number:
   Coding: 1A078A9120230A6F0079060401C6245851045000608024F0004B0020C0
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP.rod
   VCID: 3A55FE40BD3681F161F-806F
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5E0 907 044     HW: 5E0 907 044
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 01110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 62E566207526A93119F-8037
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011311102305
   Coding: 0F000942424702FB07A04082B10C07280000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_SK37.rod
   VCID: 46AD9AB0F9CEF511157-8013
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119
   Component: WWS371 130326  041 0570
   Serial number:         130404233425
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y13M04D27H02M43S45S1
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1306407NE
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000056525540
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831309301486
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3753E7748E249C999E1-8062
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P3P771Q7I
   Coding: 98CCC0000C0000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EDD3250E19E6DD11D7-802B
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 504 13
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000BEB599C0-
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 001 504 13
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U000000EAA599C0Z
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 304 13
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R56264B01000000Y
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 304 13
   Component: SideSensor_Pr  111 0148
   Serial number: 3526RCE2F4B01000000G
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 203 13
   Component: FrontSensor_D  114 0149
   Serial number: 3556V2CEC2301000000A
   Coding: 2D2D2D
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 454 800 604 13
   Component: PedP_Sensor_D  114 0149
   Serial number: 2286V55A47E000000008
   Coding: 2D2D2D
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 454 800 604 13
   Component: PedP_Sensor_P  114 0149
   Serial number: 2296VE4AB7E00000000O
   Coding: 2D2D2D
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 454 800 604 13
   Component: PedP_Sensor_C  114 0149
   Serial number: 2306VEBA97E00000000L
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 29041304400612
   Coding: 1400
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 77D32774CEA45C995E1-8022
Address 17: Instruments
Cannot be reached
   Alternator:
   Revision: AA001001
Cannot be reached
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ASAM Dataset: EV_SteerAssisMQB 008022
   ROD: EV_SteerAssisMQB_SE37.rod
   VCID: 3D5FF55CAC18B6C944D-8068
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000059454901
   Coding: 00150020DC01020000001100
   Shop #: WSC 73430 790 00127
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 012749AC90601229605-8054
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000197947
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5E0 035 874     HW: 5E0 035 874
   Component: MU-S-ND-ER    039 0171
   Serial number: S7F00205130361
   Coding: 03730101FF0000001111120100A800002F0000860100010046
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 65EF7D3C6408DE09FCD-8030
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H44 0020
   Serial number: SKZ8Z9N46004XP
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5E0 051 236 G    HW: -----------
   Component:  ECE 2015  --- 0045
   Serial number: --------------------
End-------------------------(Elapsed Time: 02:47)--------------------------
I recommend that you contact Ross-Tech for free support.
