Super glue on dash board!
Does any one know how to remove superglue off my dash without damaging anything?
I have a octavia mk2.
Glue spot is about the size of your thumb fingernail.
You'll need debonder or maybe acetone.
Whatever you use  make sure it won't attack the plastic and make it look worse. I'd start with water.
Superglue is rigid and brittle and the dash is slush moulded so has a slightly flexible soft touch surface - have you tried just pressing hard on the spot to see if the flex is enough to loosen it?
Nail varnish remover took super glue off the back of my brand new (or it was when I got it) Iphone. I don't know what it'll do to your dash, but it'll get rid of the glue. It's basically acetone.
When superglue first became available to John and Joan Rabble, they were sticking their bits to everything, it looked like the marketing was going to come unstuck.
I had to take a guy to hospital who had glued his finger to his eyelid...  Loads of water was what casualty did.
No idea if that is still the case, or if it has been "improved" since, but it seems a safeish place to start.
I would be very careful with acetone or other powerful organic solvents on a dash.  Even if it dosen't dissovle the textured skin, it may react with the foam underneath.
