Fabia 1.2 12v cold start problem
Hi all,
I have problem with my Fabia 1.2 47kw (2005). On first start of engine (cold engine) the car is not behaving as it should: After press and release the accelerator pedal RPM works unbalanced between 500 rpm and 1000 rpm. It takes about a minute or two and after that period the car is behaving normally. Diagnostics is shown too rich fuel mixture and the service technician cleaned and configured air dispenser, replaced the spark plugs and ignition coils. Unfortunately the car is still behaves the same.
You can see more about this problem on this video: http://youtu.be/slYTcfhIZUo
I would appriciate if anyone can help me.
Replacing the coolant temperature sensor and cleaning & resetting the throttle body would help.
Throttle body was allready cleaned and reset one month ago. I replaced the coolant temperature sensor (still same problem) and i am going to service to reset thorttle on next monday.
  • 6 months later...
Hi ,. my fabia behaves the same. how did you repair your car?
