Turn signal always on!?
Hallo...  :happy:
My right turn signal FRONT , light all the time ... ( when the ignition is switched off and the key removed !)
And not blinking when it belongs! Oddly !  :S
By the way, I changed the bulb with an LED ...
I have searched a lot , and have come forward to it perhaps is an encoding that is wacky out in BYTE 18 !
Do you have a bid , may have heard this problem before ??
My car: Skoda Octavia II FL year 2012
// Soren
Edited by dmann1000
Checked fuses and relays etc?
It is a sign of a knackered BCM unfortunately.
Have you had coding changes made with VCDS?
Like above^^
Wouldn't it just be to do with the LED bulb? .
What happens if you refit the original one?
Yes, I have set a new general cant bulb " Glow-wire " bulb and it did the same !!
Can i reset BCM , or should i buy a new one ???
Edited by dmann1000
You need a new one.
Has anyone ever opened up the BCM to see if it can be repaired?
**  In a Wispering voice  **
" whats a BCM "
" whats a BCM "
"It's a secret"
" whats a BCM "
"It's a secret"
** with a wispering f@rt  **
:moon:
:giggle:
BODY CONTROL MODULE
sorry, couldn't help that.
BODY CONTROL MODULE
Spoilsport!
The BCM combines the functions of the convenience and central electrics controllers.
Thanks  Anddenton........
That showed him
mine done exactly the same the BCM body control module  controls the lights on the car there not cheap either around the 300 mark
thank you all .... but I think it is my fault that it is broken, that I put an LED in the lamp ???
If it's under warranty, put the original bulbs back in, put the coding back to what it was, and take it back to the dealer. Let them try and prove it's had other bulbs in there (which shouldn't have done any damage anyway)
Mike
And delete this post just in case the dealer reads it. Lol
LED where?
Hehe.... cool... but i have not change the coding, at all :-)
