2.5 TDi cold starting
Yes, that was the topic indeed, the chap's symptoms were similar. Though I do not have a warm start problem. Just cold embarrassing smoke. Eek. Indeed I'll let you know. I still have my old needle lift injector in the garage which is broken and I'm tempted to have a play with it to see how hard it is to remove and refit the nozzle. The experience may come in handy should I choose to replace the nozzles! There is no general consensus on their life expectancy. Some claim 500-600 thousand km with no issues. Others recommend new ones every 150-200 thousand km.
  • Replies 78
  • Views 9.1k
  • I have been communicating back and forth with a diesel specialist, and depending on who I spoke to they either didn't have a clue what I was talking about or just didn't know what a new valve should l
  • I will try the zinc application on my cars. Just need to hunt down a suitable product. On the original subject of cold starting issue, subsequent diesel filter change having resulted in fuel leak,
  • Ok, update time. Been running the new heavy duty spill pipes for a few days now and must say that the machine starts very well each morning! Almost no perceivable shake at all. Yes, it is a high milea
You don't think that a single glow plug might have sneaked off for a coffee while nobody was looking   ....... 5 out of 6 cylinders come in fine, but the 6th takes a few revolutions to get there?
I don't think so, at least not in my case, since I double-checked a while after replacing them ( I read somewhere that they can get a bit unscrewed after replacement due to the thread differences between older head and newer GP).
I checked again the voltages as well, just to eliminate potential burn-off...
I think that the issue is false air intake somewhere along the circuit, since there are so many potential culprits (hoses, tubes, valves, casings, etc.). But it's a pain in the arse to pinpoint, I guess the only solution is to take it step by step (involves changing a lot of parts until you get to the faulty one), which takes time&money, scarce resources these days...
My glow plugs are all pulling 20 Amps, they are all good. I'm double cycling them and that makes a difference, so they are probably past their prime, but still functional.
BTW, I disassembled my spare injector yesterday and it is really easy. Just surprised how rough the needle is where it sits in the sac. I think I'll get all of my injectors spray pattern / pop pressure checked. By the way, the nozzle part number is DSLA142P1025.
Edited by oh_superb
