Noisy car ...
yeah, not a helpful title. Its a 1.5 petrol Scala, with about 55,000 miles on the clock
I've been aware of a drone from the engine/drivetrain for some while and now even the missus is mentioning it, and she's quite deaf ;-)
Where to start with tying the problem down ? What questions should I be asking myself ?
Can anybody recommend any garages in the NW (Wigan/Bolton) likely to be able to look at this (without first saying we'll want at least £120 for an hours diagnostics, and thats not an actual dealership)
When was it last serviced? Have the Spark Plugs been changed at around 40,000 miles or since? Has the Air Filter been changed or looked at? Have the brakes been serviced, or inspected and has the brake fluid been changed? Is the AC used and has that been serviced?
Sawtoothing of tyre treads or failing wheel bearing can be common causes of droning noises - as can loosening exhaust baffles.
Does drone frequency change with vehicle or engine speed? Does it change depending on throttle setting?
Yes to all of the above
Tires are fine, they get checked regularly. I'd say the drone is related to engine speed, but then again my hearing isn't the best
Could well be a loose baffle in one of the exhaust boxes.
Might be worth getting bearings checked if its related to speed. Does it change if turning left and right. Sons fabia was really loud droning but seemed to get better/worse when turning. No obvious play in bearing but was pretty rough and tight when turning wheel. Also if fitted on the scala check the front exhaust flexi hasnt failed.
Alasdair
Try Blackrod Service (or MOT) Station. Have used them in the past for MOTs and service/repair work. Have always been fine to deal with.
