Xenon headlight wanted (Passenger side)
Hello all,
I own a diesel 2003 L&K Hatchback which was fitted with the Xenon headlights from the factory.
Recently I noticed that the passenger side dipped beam wasn't working.  Not being particularly mechanically minded I got my local independent mechanic to take a look.  They tested the ballast and bulb from the passenger side on the driver's side and couldn't identify any issues as both worked.  They also said there weren't any error codes on the diag which related to the lights.
They suggested sourcing a used headlight unit as there may be an issue with the Igniter / internal connections which they were unable to check when they had it in.  I have found it really hard to source a used headlight unit with the associated internals in-place so have turned to the forum to see if any of you have one for sale or know somebody that does.
I have been hitting the online salvage sites but there doesn't seem to be one anywhere in the UK at the moment and sadly the dealer wants probably more than the car's worth for a new replacement.
If anybody can help i'd be hugely appreciative.
Edited by hugh81
