Clutch switch on Mk2 octavia/Revs Rise slightly on gearchange VCDS measuring block clutch switch
Hi guys as above really
everything points towards the clutch pedal switch judging by the issue of when clutch is pressed in the revs rise slightly
Is this incorporated into the pedal assembly as a whole, or is it in the engine bay area?
it does not seem like the Mk1 with a small independent switch next to the pedal
Any help guys much appreciated
Edit: trying to find out the measuring block for the clutch switch as cruise was playing up also
Sounds entirely normal to me. If you hold a dead constant throttle, when you press the clutch pedal the load on the engine drops, so of course the revs rise.
LOL when driving normallly ie: when you release the clutch and throttle at the same time the revs still jump slightly, its common with a clutch switch
Trying to find out clutch measuring block on VCDS so I can test it myself
Mine does this, quite annoying with passengers as looks like I'm pressing clutch and accelerator at the same time!
VCDS is showing the clutch switch as working when depressed as the numbers/value changes
Can it still be faulty even though its getting signal?
