Anyone know if this steering controller will support cruise?
Hello All
Wondered if anyone could advise if steering controller 5K0 953 569 AG will support cruise?
It's a 63 plate Yeti Greenline 2 with MFSW.
I have checked the Rosstech website but it's not listed as far as I can see.
Many thanks
i think it will be ok
it has been dropped and replaced with AK which shows as ok for cruise
It gives the following error on my car if I enable cruise.
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 DP    HW: 5K0 953 569 AG
   Component: LENKS.MODUL   016 0140
   Revision: FF010042    Serial number: 20140325101753
   Coding: 5082144000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDB2B34B6CD03FC9856-80A8
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0011
   Coding: 800000
1 Fault Found:
226838 - Turn Signal Switch
          B1144 12 [009] - Short to Plus
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 150
                    Mileage: 225199 km
                    Date: 2015.03.03
                    Time: 00:20:24
  • 4 years later...
Reviving an old thread in the hope that maybe a contributor is still around & gets notifications.
I have the same controller & want to retrofit cruise control, Rosstech Wiki says its highline which would support cruise but then says "no" in the box for CC/ACC
