Quick monte DRL question, will these work?
Yep they'll work fine, however most guys on here have gone for the more expensive CREE LEDs for DRLs as they are better quality with a proven record within this site.
Thanks thought they would as i've checked the fitting and it's the same as described but wanted to double check. And yeah i'm aware of that but they're just too expensive for me..thanks though
Is it definitely P21W for DRL?
Absolutely, without doubt. It's PY21W for the turn signal bulbs which have an offset pin.
Sent from my SM-N9005 using Tapatalk
They are a really good bulb, price is very good. Mine are 80w and have 4 forward facing chips. The ones linked above would be an excellent upgrade you won't be disappointed. The fact they have chips on the sides as well mean they utilise the reflector in the housing making the whole section light up with a good light spread. Do it! [emoji13]
No canbus errors with the ones in the link Jim. I had them for a while before I upgraded. I've put one of the 50w in the reverse lamp and no error light there either
Yeah will definitely get them, i've got that tinting mesh over my fogs/drls so i hope they are bright haha
I've got the spivision over mine too and still have a good output.
Do you get any canbus errors with those ones?
No none at all
