removing headlight
Can it be done without removing the bumper. I need to check the motor on.the back as the adjuster isn't moving.
Yes easy peasy. Remove indictor and then theres 3 or 4 torx to undo
OK thanks :)
There is a sweet spot with the angle. Iirc tip down the indicator end slightly as you lift it up and out.
OK thanks
