Confort/convienience module CCM problem?
I have some problems that have just started,
Windows/locks acting erratic, by what I can make out, this maybe caused by the CCM gone bad or someting.
What I have done as a temp measure is to remove two fuses, the one that controls the locking and the
other which stops the tailgate from being oopened all the tme from the outside.
Where is the CCM module located and is there a way to check/test this is the problem?
I maybe able to access to the computer diagnostics shortly with a bit of luck.
Our local Skoda (was skoda dealer) dealer seems to believe it would be around £400 for module/fitting & programming.
Thanks,
Dan.
