fabia
Hi
New to your site just found it tonight, have 2 problem with my 2003 skoda
fabia 1200 cc they are 1. Powersteering light when ignition is switched on
light on dash will go out but once car has started light will come on, have
changed pump onto another fabia and it is working ok on that car,
2. when i move of in car for a short distance centrally locking with
activate and lock all doors will open again on door switch and will be ok
untill i say have stopped at a junction and move of and will lock all dooors
again, had a renault clio on hire last weekend and it was doing the same
thing.
Would love to get this fixed as it is driving me up the walls i am a
skoda fan and have a few.
Thanks CATSON
Welcome to Briskoda Catson :thumbup:
Your power-steering problem is a common one.. its more than likely the steering position sensor... its like a "ring" on the steering column behind the steering wheel... bit of a pain to change!.
as for your central locking... a dealer or someone with VAGcom should beable to disable it.
Incorrect im afraid chappie.
The PAS sensor sits under the car in the side of the steering rack next to the pinion.
And the sensors dont normally give up on that age car. Are there any fault codes in 44 - Steering assistance?
This is a new safety feature on central locking (it can be switched off by your dealer) but the idea is to stop people entering your car whilst your stopped at lights etc.
Oviously it unlocks via button or when you take the key out.
HI
Thanks for all your replys, but have change sensors on steering rack twice, and pump need help please
