99 1.9TDi losing 1,3,5 gears sometimes.
Another problem, though I had touched on it here.
Tonight all of a sudden, no 1st, 3rd, 5th gears. Pulling away in 2nd is not ideal, though once again only a short distance from home. Once I was withing spitting distance of the drive to select reverse, in it went and on the drive all gears were back. I tried moving in all gears and none jumped out.
Up until losing them I had been returning from work, same route and speeds, and no problems this morning with any gears.
?What can cause such an issue that appears and disappears so readily?
Cable adjustment? ? dogbone mount?
Everything was fine this morning and tonight coming home, until close a mile from home, and cable adjusted as best as I was able on Sunday morning.
?Dogbone? ?Is that the balance weight?
