Rcd 510 Dab help with errors
Hi
      just this weekend fitted RCD 510 Dab all went well, new dab aerial fitted into 2009 Octavia VRS (FL) , working a treat, but as there's always a 'but ' !! After a VCDS scan I have these faults ...
Address 19: CAN Gateway       Labels: 1K0-907-530-V4.clb
Control Module Part Number: 1K0 907 530 AA    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H16 5223
           Software Coding: E9A17F0E100202001303
            Work Shop Code: WSC 20040 023 106064
                      VCID: 66C5C6DA4110A72E011-8033
2 Faults Found:
01327 - Control Module for Parking Aid (J446)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 99228 km
                    Time Indication: 0
00463 - Control Module for Digital Sound Package (J525)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 99228 km
                    Time Indication: 0
 Any help or pointers much appreciated, I have cleared the faults but they return
you need to code off parking aid in long coding helper - do you have parking sensors? does it show a visual of the car when the sensors are on?
the system thinks you do so is looking for it
also do you have the enhanced speakers? maybe previous owner did, these need to be coded off
Yes I have park sensors with visual,but it shows the back end of a tiguan as that is what the unit came out of, not sure on the speakers.
      Thanks for the info,
                           Paul
There is a vehicle choice somewhere in the stereo coding that you need to change. Given it came out of a Tiguan and shows a Tiguan it seems like it is still coded to that car. In that module you will also have an option to turn off the enhanced sound system.
Thanks adamal
                           I've seen the vehicle adaptation in Radio long coding, there are quite a few choice's, all being from the VW range but it also has ' let can decided ' or something on those lines. I'll give that a go. :happy:
