ATD engine - leak from the tandem pump and noise from the transmission
Hello,
There is a leak from the tandem pump (ATD, Octavia 1U5'04), I see in ETKA that there are two seals from rubber (8-shaped one and one with strange form) and оне garnish like seal. I got only oil leak (the fuel is ok), what I need to buy - only the rubber seal, the garnish or the two types together to stop the oil leak?
The other question is about my transmission - I got the 6 speed 02M trans. When I got from 4th to 5ft or from 5ft to 6th and I release the clutch (when I'm engaging the clutch) I got strange one moment metallic noise. What is the reason, can it be low oil level? The noise is only in 5ft and 6th gears.
