Part number request
Hi,
If anyone has access to part numbers I would appreciate some help.
I need a part number for a carbon fibre effect radio surround with the following dimensions.
220mm at the top of the unit
210mm at the bottom of the unit
Many thanks.
I am removing the bolero unit and installing an aftermarket unit.
Anyone ?
Without measuring my old Stream unit, that actually sounds like a similar shape to the Stream unit, which is the same as the Bolero I thought??
Anyway the base part number for these trims is 1z0858069 but then there are colour codes and other suffixes dependent on the head unit and heating or climate functions.
I was going to swap my units around (Kenwood 521 DNX DAB in the Blue CR to the Green Petrol Bolero and vice versa). However, the Bolero is much larger than the other one. I think the surround I need is the standard one for a double din.
Can anyone help with a P/N?
The hole in the Columbus one is more rectangular if that is the one you mean? But they all use that base part number and you thrn spcify head unit, colour and heating controls.
Yes that is the one. I am planning on fitting an aftermarket unit but it has the same dimensions as the columbus. The bolero unit is just not up to the job for me.
If you could tell me the part number I would appreciate it.
Its that 1z0858969 I mentioned previously. But you need to state Columbus head unit and whichever climate/heating you have etc.
Thanks. It looks like a trip to the dealers or tps then.
Try skodaparts.com too.
