SD card problems on Columbus RNS-510
Has anyone else experienced any problems with the SD card on an RNS-510? I keep getting an error message saying "SD Card Error, please check SD Card" I have formatted the card as instructed by how to guides on the internet and have even played around with formatting it differently with the same result. Does anyone know what my problem could be? The music files on the card are also in Mp3 format.
Is it an older unit and an SD card bigger thsn 2GB?
Version C if that means anything to you. The SD card is also 8gb. Is that too big? I read somewhere that it should work with 8gb or less. I would like to use the biggest possible really.
You can be limited to 2GB if it is on the older firmware.
Do you know which you are on? Press and hold setup for 20 secs and you may get the secret menu to tell, or failing that pop the unit out and check the label (which will of course be wrong if firmware has ever been updated).  The other thing you can try is a 2GB or less card and if it works you know that is the issue.  It can then be made to accept 32GB with a firmware update.
Adam
I will have a check but I'm sure its quite up to date. I will post on here when i do. I will also try the lower 2gb SD card and see if thats the issue
