columbus
can you alter the default page, mine defaults to radio can I change that to sat nav
No the unit will only default to either radio or media..... Whichever it was on when powered off.
I find this annoying too. Surely sat nav should be the default.
I don't know anyone who uses the sat nav EVERY time they get in the car so why would it be the default?
i use the radio but it is set to a particular channel so do not need to change and unit looks nicer with map showing , personal taste
so not the sat nav but maps then if that clears it up
Yep. Same here. I meant map on start up.
I presumed you meant map anyway. :)
But unfortunately it's just radio or media i'm afraid. ;)
