Alloy Repairs
Does anyone know of a good place for repairing alloys within the Barnsley/South Yorkshire area.
Managed to take a great chunk out of the the rim of the alloy by clipping a causeway this afternoon. Tyre is a write off as a wopping big chuck has gone from the side wall, and it bore the brunt of the impact.
Below is the type of alloy that I have damaged, anyone potentially got one for sale? Incase I cannot get it repaired. :)
Try trawling the breakers on the net, A single wheel should be easy to find. If youve hit it hard enough to take a big chunk out of it you might also have knoked it out of shape, your local tyre depot can run it up on the balancer & see if its buckled, a
Also worth getting the tracking checked when the new one goes on :D
Chris
If you've removed a big 'chunk' as you put it, I think you should look into replacing. I'm sure getting it fixed will cost almost as much as a new one, and with metals, one-piece is the way to go, because that wheel will never be the same.
Get it replaced man.
Good point - otherwise it will end up using up tyres a lot quicker than it should potentially
