LPG for Diesel
Just had this email back about lpg conversions for diesels
Anybody on here already had the conversion on a diesel?
SpongeCars introduce the gas assisted fuel system for diesel vehicles.
* Installed by Alternative Motoring Solutions
* Expect net fuel savings between average 20 - 35%
* Increased performance
About the conversion:
The Multi-Fuel System (MFS) as installed by Alternative Motoring Solutions
Ltd is the economically realistic alternative fuel solution to reducing
vehicle emissions and cut fuel costs.
The MFS is a patented 'dual fuel' alternative fuel system that enables any
internal combustion engine to simultaneously combust a gaseous alternative
fuel with the existing use of diesel fuel to achieve 'near-zero' emission
levels with increased fuel economy and performance.
Systems are available for virtually any vehicle type; from sports cars to
performance cars to passenger cars to LDV's and HGV's, even small engine
devices such as lawn mowers and generators.
Decades of research and development have gone into the engineering of the
Multi-Fuel System to ensure consumer friendly operation and safety with
improved engine operation.
The MFS controller is installed in the engine compartment and uses solid
state electronic management to vaporise, treat, and control the LPG with
triple redundant safety controls.
Treated and vaporised LPG is injected into the engine's intake manifold,
homogeneously mixing with the engine's intake atmospheric air. Liquid fuel
is injected into the cylinder as it was before. Under the compression cycle,
the air mixed with the LPG heats to hotter temperatures due to the
alternative fuels higher 'heat of vaporisation'. This forces more of the
diesel to vaporise and volatilise giving a quicker and more spontaneous
combustion resulting in increased power without engine modification. The
power increases, in part, are due to the increase in volumetric efficiency
from the requirement for less oxygen (air) in the air/fuel/alternative fuel
mixture charge and maintains the engine's stoichometric (optimum fuel mix)
ratios. Although the alternative fuel should increase the temperature of
combustion of the fuel of the fuel mixture over the dedicated liquid fuel
combustion, this has not been measurable and is believed to be negligible.
Since the diesel is virtually vaporised and since combustion is more rapid
and complete there is one explosion, consuming the fuel and releasing its
energy. As there is no 'combustion wave' diesel knock is reduced. Since
there are no additional explosions of the combustion wave, excess heat is
not generated, reducing the formation of NOx and stress on the engine
cooling system. Cooling system temperatures remain as before, because of
thermostats, electronic cooling fans, etc. but engine oil temperatures are
reduced.
Additionally the properties of LPG dissolves carbon and tar deposits after a
period of operation improving the efficiency of the engine, this in turn
extends the life of the oil and reduces engine wear.
Benefits...
A gas tank of approximately 25-30% of the diesel tank capacity is all that
is required for 'combined' refuelling stops. Should you run out of LPG the
vehicle continues to run as a normal diesel without any intervention by the
driver. When the LPG is refilled the vehicle will automatically return to
its green, clean and cheaper state, saving an average of 20%-35% in fuel
costs.
SpongeCars and Alternative Motoring Solutions - driving to a cleaner future.
There was an interesting article in Dieselcar a couple of years ago on this.
There was a tuned golf tdi running the dual fuel conversion and it was putting out appox 10% more power form memory with the LPG and diesel.
