SuperB rear LED light coding
Hi, I have Superb 1/2011
I need help with coding LED rear lights.
at BCM - Controller 09 I got this LCODE
40190ABBE80508C040080080310089E4437000AE736D85605C8140000040
I tried various settings BYTE 18, and so far the best function on BYTE 18 is setting 2F
DRL lights and rear all OK, just not functioning fog lights
Unit has a number: 1K0 937 087 P
can you help me?
and where do I set checking the bulbs?in Lcode is only disable License plate monitoring
You can't do it using VCDS only (or at least no one has figured out how as yet).
It can be done but you need access to both VAS and VCDS together.
VCDS to alter the long coding and VAS to tell the car it is a 2012 instead of earlier 2011 model.
As Coops has linked above there is more detail in this thread.
If you don't code the lights correctly then the lower row of LED's illuminate at brake light brightness when in tail / night light mode.
