6 speed gearbox from ASZ engine to ALH engine
Hi
As per title, could i fit this gearbox to mi octavia with ALH engine code? Gearbox comes from VW golf mk4  1.9 tdi 130pd ASZ engine code.
Yes, but you'll be needing the clutch as it'll be 240mm, the shafts and the hydraulic clutch pipe that runs along the back of the bulk head, you'd be better and cheaper just to keep it the way it is as i have 2 6 speeds and would rather have the 5 speed
Ok Thanks i will leave it as it is...But manny times the car is asking for the 6th gear...
