Maxidot retrofit washer fluid level
Me again, does anyone that has retrofitted maxidot to an s spec octavia know which wire needs shorting to ground to disable the low washer level indicator? S spec has no washer level sensor so indicator light is permanently on. Thanks
ehm... better is dissable washer sensor via VAG/VCDS...
I did look for it in vcds but could not see it under instruments. May have missed it. I know Eddie fitted the sensor but I don't care about it and don't have his skills so a quick vcds turn off would be great.
Thanks for the help
Went back to it and found the issue, the pre fl maxidot speedo doesn't seem to support long coding so had to do it old school. I had a 7 where I needed a 2. Wash bottle sensor now disabled.
Edited by Nikonite
You are welcome;)
And same way for safety belt warning...
Edited by karlos1987
