Stupid simple question
Fabia 3 1.4tdi 2007 plate
How do you reset the service now display on the dash
Looked on tube last time it was done they used the computer
Tried the push button ign on etc etc with no joy
I no longer have access to VW computer and would be grateful of a sensible answer
Thanks Buckers
I believe if u have a trip computer, if u hold the up button on the end of the rh stalk, it takes u into settings. Then located under service interval
Good try but only takes you to MFD, Langauge, display off and something else
Engine off at the time as you get a different extended menu when the engine is off so maybe try that?
Sent from my SM-N9005 using Tapatalk
