Who needs Fabia vRS Fog Lamps??
More info.
Interestingly the Felica ones can be fitted with a spare glass.
nice find :thumbup:
Shall I give myself a pat on the back??
I cannot be 100% sure they will fit so purchase at your own risk.
Felicia face lift foglamps are the same as the ones used in the Fabia, so they will fit.
I was told that they were the same part number, however experience tells me that they are not. The fittings are different, the Felicia ones are held in with screws that pass through the vertical plane, whilst the Fabia ones pass through the horizontal plane, also the lens styles are slightly different. From the part numbers if you substitute the H for a M then you get the Fabia part numbers. How do I know this? I had to get one for a customer who came in and we tried to fit the Felicia one, he had to come back later for the correct one.
