help please croft is 8 days away!
can someone link me up or point me in the right direction to the following please mk2 pre fl -
some led sidelight (ones i tried fitting flickered then went off and through the warning light on the dash),
gearstick top replacement part.
Cheap Splitter/compatible splitters
thanks in advance :)
I had same issue with sidelights couldnt find any that worked, guessing your heading to the summer maddness event up at croft?
Gearstick i fitted a mk3 vrs one looks much nicer than the mk2 (not direct fit but easy enough to sort)
sadly cant help with splitters i havent even looked yet barely got my vrs bumpers on, however havent a few fitted the ever common cupra R front splitter?
Dan
yeah i am Dan :)
ill have a look into the cupra r splitters!
ive just ordered a canbus error resistor cable so hopefully that will work! ill let you know :) the sidelights look daft with xenon lights =/
