Getting the lights to stay on when you turn off the car
i read in the handbook (fliping hell reading the manual)
that you can get the lights, dipped beam i think
to stay on when you get out the car
it rekons you
turn off the lights
turn off the igntion
flash the main beam
if the door is open the lights will stay on for 3 minuites
if the door is shut it stays on for 30 seconds
does it work for anybody else
i cant get this to work am i just a binner ?
Don't think the Vrs has that fitted
That would be correct!
at least next door will stop wondering why i keep sitting on the drive flashing my main bem ever night when i get home
which octys does this work on then?? :confused:
You can get the sidelights to stay on via normal switch and you can get either L or R sidelight to stay on by turning the lights and ignition off then use the indicator stalk for whichever light you want on.
Don't think you can get dipped beam to stay on after the ignition has been turned off tho (why would you want to?).
Park the car at the bottom of the path ,,,,,,,,switch off........remove key .......pull headlamp stalk to flash lights .....open door dipped headlights come on and stay on for about 30 seconds ...plenty of time to get to the door :D
