gearbox oil change
Hi all, Got round to changing the gearbox oil today, I couldn't believe the colour of the old oil that came out, almost black. I can recommend to anyone thinking about changing the oil to do it..
Did you have a drain plug? I am looking to do mine asap but I read on here it needs a pump to do it. I am pretty sure I saw a drain plug on mine but I cant get it up on ramps here to check as I have a useless gravel drive. I have the 105 1.9 pd
Mines the 2.0 with 6 speed gearbox but yes it's got a drain and refill plug, Needed to buy a 16mm splined anti tamper bit to get the plug out. I had to do it with the car on ramps to get access, Measured how much oil came out and put the same amount back in, With yours being the 1.9 i don't think you have a refill plug, It will need refilling via the reverse switch in the gearbox i believe.
