removing temp sender 1.4mpi
hi this should be my last ask at the minute. i'm ordering a new stat, housing and temp sender. i've just had a look to make sure which temp sender it is and i thought i'd quickly ask how the connection removes from the top of the temp sender. i can be quite ham fisted at times and don't fancy busting the connector.
thanks again in advance rob
Dead easy. Put your thumbnail under the tab (where my thumbnail is) and pull the tab straight upwards at the same time as pulling up the plug....
thanks
