Steering angle sensor - Is 6Q2423291AXX replacement for 6Q1423291
Hi,
help needed please. Is part no. 6Q2423291AXX a direct replacement for 6Q1423291? It just does not look the same i.e. mine has a square block between the cable connection and the torx/allen bolts that secure it to the shaft but the replacement appears to butt straight up to the shaft. Can anyone clarify if they are interchangeable?.
Many thanks in advance if anyone can help
Gav
There is normally a choice of 2 you would have to check with your local dealer .I think it depends on steering rack brand
