gears not working
Hey
This morning I was driving my car and suddenly a sound started like something got dettached. I stopped the car to check and found noting. Then again when I put a gear the gear went just fine but after that when I left the clutch. The car didnt moved. Now when a friend of mine towed the car from his own car and there was a sound in the car cabin from front axel I guess. maybe you guys can help me find out where the problem lies. And I also saw those levers move under the hood when I put a gear.
Impossible to diagnose on line I would think. Needs a mechanic to have a good look at it. Good luck with it.
Possibly drive shaft joint collapsed. Had it before on a Citroen van and had just the same symptoms as you're describing.
