Stream Head Unit Questions.
Does anyone know if you have to put in a code once you have disconnected and and re-connected power to the Stream Head Unit. Dealer didn't give me an code
How do you 'select' the AUX input. I know how to turn on the 'Aux' input in the stream menu but not how to select it.
You shouldnt need to re enter the code if it goes back in the same car, hence the dealer no longer gets supplied with the code.
Just turn the headunit on with the ignition on and it should code itself.
You shouldnt need to re enter the code if it goes back in the same car' date=' hence the dealer no longer gets supplied with the code.
Just turn the headunit on with the ignition on and it should code itself.[/quote']
Thought that was the case, cheers Lummox.
