Snow Foam Lance for Aldi Powercraft
I bought a Karcher snow foam lance that was on offer in a local store but it won't fit my Aldi power washer. The two lugs are too wide to fit into the main body of the lance. Has anyone else seen this problem and should I just file down the lugs to make it work? You can see it at the following link
http://www.amazon.co.uk/K%C3%A4rcher-FJ10-Connect-shampoo-2-643-144-0/dp/B00HH9QI6W
Edited by WheelSpin
Cheapest or intermediate solution is the file down method obviously....
Alternatively get a new screw on fitment for the lance and re-fit.
Or upgrade the Gun and hose to Karcher fitment to match the foam lance;
if you upgrade the hose you can order a 10metre or longer, for example - which is a useful upgrade too :thumbup:
It appears that my Karcher lance has the same screw-on fitting that is shown in the link. The Aldi gun requires narrower lance lugs than the Karcher gun even though Karcher made the Aldi washer.
Will. It does mean you have to hold the gun sideways but it does the job superbly.
Hats off to the seller as well as he bent over backwards to help and ensure I bought the right fitment.
Ah yes - I see the issue there; typical Karcher/Powercraft design limitation.
Would it be possible to adjust the original foam lance fitting a further +/-90deg?
Or look at getting the correct fitting longer term perhaps?
Still - at least you are up and running - happy detailing :thumbup:
I suppose you could adjust the fitment on the lance, but it really isn't that big an issue. I was just happy to find one on ebay!
All good then - cool! :thumbup:
Happy detailing :yes:
