Please help
Hi folks. Sorry to be a pest but I really need advice. I've not long had my wishbones and bushes, droplinks and track rod ends replaced and last week I replaced the arb bushes n since then, there has been a major rattle from the front of the car when I go over uneven roads. It's proper loud. It's running ap coilovers. Please could someone give me any ideas please. Thank you in advance.
who replaced them sounds like droplinks but something could be loose
The wishbones, console bushes, track rod ends and drop links were done by a garage. I done the arb bushes. I had the passenger side wheel off last night (that's where the noise seems to b coming from) n had a check of all bolts. All seems tight. What r the benefits of shortened drop links? Thank you for your reply mate.
Are the ARB bushes the correct ones.  The hole for the arb could be too big?
SN
shorter droplinks only required if you got coilovers and are going really low I got ap's atm and ain't got shorter ones as they are not needed, jack car up pull wheel from side to side, up and down see if you can feel any play soundfs to me like somethings loose
SN
I believe so. Standard rubber bushes and they were a pig to fit haha.
Turns out the threads had stripped off the top bolt of the droplink on the n/s. 2 months old!! Shocking.
