How to tell if fixed or variable servicing?
Hi Everyone,
I have a 2013 fabia monte carlo,
I bought the car second hand a few months ago and I'm not sure whether the car is on fixed or variable servicing.
My car has a maxidot display if that helps...
I called the garage and they told me they need to plug it into 'their computer' to check. Surely I can check this within the maxidot or something?
Can anyone help?
Welcome to the forum.
Can you go into the Maxidot Menu and see what it shows as when the next service is due.
Has the car got a Service History, did the Dealer Check for you when last Serviced / Oil & Filter Changed?
They can check from your Registration Number if done at Volkswagen Group Franchised Dealerships.
Does your car have a Service Book with it to still to check in?
What do you want,
annual Services or at 10,000 miles or less if you do that mileage each year.
So how many miles has the car done,
what services has it had,
& what does it need.
Do you want to go for 18,500 miles between Oil & Filter Changes because your engine can if you want,
** If at the last Service the Correct Grade of Oil was Used, and it was 'Long Life' Full Synthetic'.**
 When the car is in at the Dealership, have them set to Variable or Fixed to suit your type of miles per annum.
george
Edited by goneoffSKi
