Maxi dot instrument cluster on ebay
Not sure if it is may be someone could confirm
Search item no 191569329185
Not mine I might add, it is cheap!!
cheers for that, it's now sold :happy:
Says it's sold.
Doesn't look maxi-dot or say it is.
Says it's sold.
that's cos I bought it :D Worth a punt for £30, even if I get it to get Charlie to do a white LED conversion,,,,,,,,,,
Reminds me of some Fabia seats that were gone in the blink of an eye. :D
Fingers crossed it is maxi-dot for you then, part numbers don't say so though.
Worth a shot as a spare I suppose :)
yeah, prob not maxi dot but still cheap :)
That's definitely not maxidot. You can tell from the picture that the bit in the middle is just a blank and not the screen.
Phil
Phil
Kill joy :D
"Picture for display purposes only"
....maybe.
Clusters are generally not that much due to the re-coding work needed to get them working in another car.  Not convinced they will be able to work in your TDI to be honest.
Will the red needles on those fit the poverty-spec cluster that has white needles?
my parts bin's getting bigger :(
Needles are just pop on / pop off, so can in theory be swapped.  As can I guess the backing film with all the speeds etc on them,
So there is a chance of a bit of a transplant of parts of the vRS clocks into the TDI clocks. :)
Saying that, the speedo calibration will be out as the vRS clocks get to 90mph then go "half speed"
TDI clocks are all the same speed through the range so I doubt if you used the vRS backing film, it would ever read the right speed (apart from at standstill :D)
I've never messed about with these clocks, but I have read if the needles are removed or messed about with, they need calibrating.
Thoughts?
I've messed with mine and they work perfectly
that's without light cars currently having some serious work so no battery on her atm they light up blue really bright more pictures to follow
You not sorting maxidot you bought Steve?
yes and these will be up for sale but serious work going on atm she's in pieces
I know the feeling!
