Passenger Seat Removal
Hello,
Could somebody please tell me how to remove the passenger seat from an Octy vRS? I've heard that it is surprisingly easy to do, and I need it out! lol
Cheers people :D
:thumbup:
Slide the seat as far forward as possible, remove the plastic trim at the rear of the runners (self tappers IIRC) then slide the seat back as far as possible, this then exposes two bolts at the very front of the seat, lift seat up at the front and disconnect any plugs for airbag etc (if fitted) and lift out - 5 min job.
Yep, what he said. On the furby there's no trim to remove so it literally is, slide forward & remove rear bolts, slide back & remove front bolts. :cool: No electrics to worry about either.
Yep, what he said. On the furby there's no trim to remove so it literally is, slide forward & remove rear bolts, slide back & remove front bolts. :cool:No electrics to worry about either[/color'].
So do I understand then that you've got the "Cheap-skate model"!!! :D:thumbup::thumbup:
