Wheel alignment
Can anyone tell me exactly what needs adjusted for the front and back alignment. Im wanting to make sure everything is free to be adjusted i know its the tie rod ends for toe just not sure what does the front camber
At the front it's only the toe with the tie-rods and you can only adjust the difference in the camber by shifting the cross member - eg:  If the LHS is -1 & the RHS is -2 then it might be possible to shift the X-member to the Left (12mm bolts in 16mm holes) so that you get -1.5 on each side.  Most green light aligners don't know this.
At the rear there is a separate eccentric bolt for the camber & the toe
