Help!
Hi all I was out driving today and after about 10 minutes a light came on the dash in where the milometer is. It's a exclamation mark in a triangle with a clockwise arrow going around it, does anyone know what it is? Have lost my manual, thanks in advance :-)
It could be a vast number of things. The first suspect is usually the Mass Air Flow meter. Check for fault codes.
You've not just accidentally knocked the ASR button on the dashboard have you? :)
No I've checked that it only comes on after around 10 mins of driving then goes off again when engine is turned off and back on but repeats again if I drive for another 10 mins :-/
Could be some issues with the wiring but it could also be any number of things. You'll need to get your local garage to plug your car in and take a look at the fault codes. Alternatively if you can find a Briskoda member with VCDS in your area they might be able to take a look for you.
As mentioned that tcl can signify issues in the abs system or maf sensor, scanning will be your friend.  In the meantime if you get chance and it is safe, brake hard and see if your abs cuts in, might help narrow it down
