N75 BOOST VALVE Malfunction
Hi all
My vRS MK1 has run 55000 KMS and all of a sudden there is a spluttering and power loss at the point where the Turbo has to boost power around 1800-2700 RPM and post 3000 RPM the car runs good.
There are no Error logs when connected. So the culprit may be the N75 BOOST VALVE.
I hears that it can be replaced with the latest upgraded version 06A 906 283E.  Is that true ?
Any other information will be helpfull.
Please need your help
Diverter valve would be my first suspect. If your car is a standard VRS 06A 906 283F  is now the correct valve.
Edited by pauldazzle
I got the  Item Shipped from Ebay UK and the item was shipped in a weeks time. It was a quick delivery and this seller has super good parts for SKODA
Now the Red Devil is back to the former glory. And I have started feeling a faster heartbeat while driving  :)
Thank you for the help and information shared !!!
one question, if the N75 is faulty, will it show a error message ? perhaps check engine light ...
Unfortunately no nothing comes up. No error logs also when connected to ECU.
It was a trial and error and also an experienced mechanic can suggest.
When the shuttering issue creeped up the mechanic here removed the N75 Boost valve and did a direct connect. So the car did not have a  Boost pick up but was running like a Naturally Aspirated car. But the shuddering was not there it was smooth 90% of the times.
